- 22 Apr 2007
Installing an HR-01Plus on a Gigabyte GA-MA78G-DS3H.
The backplate is not held securely to the rear of the mobo. There is a large amount of rattle. It was not like this when I installed the same heatsink on a Socket 775 mobo a couple of months ago.
What gives?
EDIT: Never mind: just done a dry run; everything seems suitably tight once the spring-loaded bolts are fully tightened.
What gives?
