HR-03-Plus Installation
I'll use this as a reference: http://www.thermalright.com/a_page/main_support_installation_hr03-plus.htm
What I mean is, on "Installation1 - Step 5", I'm not entirely sure what to do. The HSI chipset has a tiny core in the centre, which i guess is where you apply the thermal compound. And the HSI heatsink, it says apply at the bottom, but where is that; won't that put thermal paste all over the HSI Chipset, including its electronics?
The core on gfx cards look a lot like the old athlon cpus (xp****) so yeah, just apply the compound to the small chip in the centre.
