Hi chaps,
I've had conflicting comments on whether my HSF is the wrong way round. Could someone please settle this?
Basically... 1 fan sucks in air at the front, an exhaust blows out the back. The HSF fan is blowing out towards the exhaust fan. I don't know the physics behind this if the fans are at different RPM/shifting different amounts of air and whether this is good or not.
There's a vent at the top of the case so I was wondering whether I should have the HSF fan blowing air upwards instead?
I think this would not really help as the PSU would then be sucking in warm air... Case is a Lian Li PC-something-or-other.
Code:
_______....______
<- PSU | |
|_____| |
120mm <- <-||==== HSF |
<-:GPU <- <- 120mm
|_________________:
There's no fan in the top, just vent holes. I didn't bother fitting one as I assumed any hot air there wouldn't need help escaping. Saying that it might draw more cold air up over the CPU but 2 exhaust fans and 1 intake fan doesn't seem balanced?
