HSF fan, suck or blow?
23 Oct 2002
Hi guys, my HSF fan broke so i had to get a replacement, but i cant remember if they are supposed to suck or blow.
the replacement fan i have is a coolermaster but i cant remember the spec for it now.
am i right in thinking this fan should suck from the heatsink? there is another case exhaust right above it.
hmmm, no idea. its my workstation so its been a long time since i bought it. its got a big old corsair heatsink though. its an OCUK overclocked bundle so im assuming it was a half decent one. but i cant find my old order.
If you look at where the air will be flowing in your case this can help e.g. if you've a fan exhausting from the case just behind the heat-sink (pretty common) then you want the air generally flowing towards it. So if fan is on far side then blow onto HS and through to the vent, if on same side then pulling from HS towards the vent. If at 90 degrees to it then see if the top has intakes or venting fans and use the same logic.
