I've been looking at trying to quieten down my computer for a long time now, but only over the last few weeks have I actually started looking at specific components I want to buy. After a bit of research I decided that I should replace the HSF on my CPU, the cooler on my graphics card and the case fans that currently occupy my case. After looking on various forums and websites I decided that I wanted the following:
Arctic Cooling Freezer 64 Pro CPU Cooler
Zalman VF900-CU Quiet Copper VGA Cooler
and 3 maybe 4 Akasa AK-182-L2B Ultra Quiet 80mm Fans (with 3-4 pin adaptors for each. These would then be connected to the speed controlled fan-only connectors on my power supply, which is an Antec Truepower 430W).
However the only real concern I have left is the recommended heatsink weight for AMD socket 939 processors which is 450g. The freezer 64 pro seems to be one of the lightest HSFs out there, but it is still over the recommended weight at 530g. This issue probably does not concern most of you as you probably don't move your pc around much, but I have to take my computer back and forth to university every few months.
So what I really want to know is should I really be concerned about the weight of heatsinks I use with my processor? Also are their any decent HSFs out there which fall under the 450g recommendation (the main idea of this little project is to quieten down my rig and I do not plan to do any overclocking at all in the immediate future).
