.htaccess not working for some reason
4 Mar 2007
United Kingdom
Okay, it could be the fact that i'm not the best with dealing with .htaccess files
however my general site path is as follows:
index.php?page=index
where further modules can be assigned like so:
index.php?page=index/category/id
it even works for
index.php?page=index/category/sub-category/id
Now i've got the PHP which sorts this fine, works a charm, but I need to get rid of index.php?page=$1
I've tried
Code:
Options +FollowSymLinks
RewriteEngine On
RewriteRule ^(.*)$ index.php?page=$1
But to no avail it doesn't seem to be working at all. Any ideas ?
I really need it to display
http://www.site.com/index/category/id
instead of the long windedness
Regards
Add the [R] flag to the end of the rule so you can see where rules are sending you, might help you find a solution!
I think (my mod_rewrite skills leave a little to be desired..) that your problem is that your rewrite will get stuck in a loop;
user visits site.x/index/category/id
/index/category/id matches ^(.*)$
redirect to index.php?page=/index/category/id
but thenn...
index.php?page=/index/category/id matches ^(.*)$
redirect to index.php?page=index.php?page=/index/category/id
... and so on, or something dumb like that
ANYWAY
try
Code:
RewriteCond %{SCRIPT_FILENAME} !-f
RewriteCond %{SCRIPT_FILENAME} !-d
RewriteRule (.*) index.php?page=$1 [L]
This is similar, but won't execute the rule if the page being requested is an actual file or directory. This stops loops and will let you do things like request a CSS file correctly; if you tried to do that before the rule would catch it and run it through index.php!
but thenn...
ANYWAY
try
Code:
Brilliant, it didn't work all the time for some reason, but after a bit more research I tried this and it seemed to have done the job.
Code:
RewriteRule ^(.*)$ index.php?url=$1 [PT,L]
