htc kaiser/vario III etc ppc with built in gps and tomtom
20 Oct 2002
Bromley
m having hooge troubles finding the right software that supports the built in gps
reading here its a specific version i need, i have a older version that works but only with a bluetooth gps which i no longer have!
It says something about copying over the .exe file with another version!>??
I downloaded the .exe thats supposed to support the kaiser but then it tells me to update the firmware on the phone!
Can anyone point me in the right direction. thanks!
http://forum.xda-developers.com/showthread.php?t=330235
downloaded the file from there and it says my rom needs updating!!??
all i want is tomtom and it to work!
anyone help?
didnt seem to work for me...
What version are you using and what maps? as it seems very iffy on the kaiser.
I just installed tom tom7 from htc and i downloaded one of there trial maps which is a very small area round where i live and it works like a charm . but then you have to pay for the extra areas. I dont mind that but one of the packages with some uk maps in would be better.
