HTMl / Email Help!!!!
Email clients and decent HTML/CSS do not mix - recent versions of the desktop version of Outlook use MS word to render HTML emails, some web-based email clients will strip off the <head> tag, including any styles you declare within, others will ignore certain CSS properties.
Tables and inline CSS styles are the way to go if you want your email to render reasonably well across a wide range of clients - http://thesiteslinger.com/blog/10-tips-for-designing-html-emails/
Interestingly it works now!
Dump the Javascript bit. It probably won't work and might get your emails blocked as well.
As Oz.... says, email clients are a bit rubbish when it comes to rendering. Do you know that all your clients will be using Outlook? and not just viewing the email as text?
It might be easier to send it as an inline picture in all reality.
Most email clients will block HTML by default until the reader confirms by right clicking and downloading images. Make sure you have a good text version to use as well.
