Hi there, im looking to make a clever little form to store all my CD-Keys on for when i goto university, as i dont want to take the game boxes/CD's with me... I am sorted for the disc ISO's, but all the serials i have are in a .txt file and isnt very interesting. I thought it might be cool, and it will kill some time, if i could make a little HTML file, as i cant code in C++, so i figured, some forms, a window restricant, and done! So far, i have a short list of the programs i want on it, and a button. Luckily for me, i have forgotten everything we did about forms in A-level IT, thanks to a teacher who was most of the time reading out of a book : /...
Its basically this so far:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
<script type="text/JavaScript">
function MM_jumpMenu(targ,selObj,restore){ //v3.0
eval(targ+".location='"+selObj.options[selObj.selectedIndex].value+"'");
if (restore) selObj.selectedIndex=0;
</script>
</head>
<body>
<form name="form1" id="form1">
<select name="menu1" onchange="MM_jumpMenu('parent',this,0)">
<option>Photoshop 7</option>
<option>Office XP</option>
<option>Select program...</option>
</select>
<label>
<input type="submit" name="Submit" value="Fetch CD Key..." />
</label>
</form>
<form id="form2" name="form2" method="post" action="">
<input type="text" name="textfield" />
</form>
<p> </p>
</body>
</html>
Is there any way fo outputting a CD-Key into the Text box underneath when the button is pressed, and do i need to make a database or anything with all the numbers and programs on... This has gone from a little side project to something that im rabid on completing! Your help is appreciated!
Thanks
<head>
</script>
</head>
<body>
</select>
<label>
</label>
</form>
</form>
<p> </p>
</body>
</html>
Thanks
