HTML Help Please
14 Oct 2007
I am trying to finish my website but having a big problem with the 'Contact Us' page. I want a form so people can submit me an email.
I need to have the following:
Name:
Contact Number:
E-mail:
Comments:
Issue:
for the 'issue' field, I want it to be a drop down box where they can select from '4' things...
Can someone help me out and provide the coding please?
Thanks in advance
Code:
<select name="cboSelectField">
  <option value="1">Option 1</option>
  <option value="2">Option 2</option>
  <option value="3">Option 3</option>
  <option value="4">Option 4</option>
</select>
Obviously, you'll need to change the values and labels as needed.
<select name="issue">
<option selected="selected" value="item1">item 1</option>
<option value="item2">item 2</option>
<option value="item3">item 3</option>
<option value="item4">item 4</option>
</select>
<option value="item4"> <-inside the quotes is what the value is.
item 4</option> <-item 4 is what is displayed when a person sees the drop down.
If you tell me the values I will fill them in for you.
Oh I see you need the whole form...
yeah, the whole coding for name, contact number, the whole lot...mine didnt turn out right after over an hour of playin around, i then couldnt get it to email to my address after :(
that doesnt tell me how to put the mailto: in either...
Can someone submit me the full code and put CAPITALS where I need to change things please?
Code:
<form name="ContactForm" action="mailto:[email protected]" method="get">
  First name: <input type="text" name="fname" /><br />
  Last name: <input type="text" name="lname" /><br />
  Contact: <input type="text" name="cntact" /><br />
  E-mail: <input type="text" name="email" /><br />
  <hr />
  Issue: <select name="issue">
</select>
  <input type="submit" value="Submit" />
</form>
Try that ;)
Code:
<form name="ContactForm" action="form script link" method="get">
  <hr />
</select>
</form>
Try that ;)
Perfect!!! BUT...where do I insert the mailto: line so the forum gets sent to my email address?
