HTPC 4K requirements.
rjk
rjk
OcUK Staff
8 Aug 2007
Hi all.
It's been a while, hope you're all good.
I have a htpc with an I3 3220T CPU. This has ran everything I needed until now as I have upgraded my TV to 4K.
Do I just need HDMI 2.0 cables?
4K isn't a selectable resolution so I'm guessing the IGPU doesn't support it.
Looking for advice on a suitable graphics card to run 4K video. Gaming is not a consideration.
All comments appreciated.
Then yeah, can't go wrong with that card then.
Sorry just edited my previous post. I am not sure about the encoding part.
Radeon RX 550 does both according to official AMD website.
It is a bit more expensive though.
If you downclock a 1050 can it be run passive?
With a custom fan profile to kick in at high temperatures just for safety?
Maybe even the 1030 would work for that too??
