Hello,
hopefully I'm in the right section!
If you can help me then it will be appreciated. I want to create a new home cinema media PC. I'm after a very small chassis and if I can use the existing hardware i already have.
So, what I already have that i can use...
Shuttle SD37P20
Intel Core 2 Duo E6700, Conroe @2.66Gz
Shuttle, Glenwood-DG Motherboard
2 x 1Gb DDR2 - PC2-4300
Nvidia GeForce 7300 LE
I will be changing the Gfx card to have a HDMI output (i assume i don't need anything major as i'll only be playing video and not gaming on this system). At the moment it's pretty noisey as well so i'll be changing the fans to something a bit quieter. currently 2 x 80mm, 2 x 60mm and the stock cooler for the processor.
Thanks!
Shuttle SD37P20
Thanks!
