so ive just bought one of the LG BR/HD-DVD readers and installed it into my WMC 2005 box:
E2200 Conroe Core 2 2.20GHz
ASRock 4CoreDual-SATA2 R2.0
2Gb DDR PC3200
ASUS ATi 3650HD AGP
now the ATi is rated for BR, it has VC1 and H264 hardware decoding support etc. however bunging transformers BR in the drive with powerdvd7 it fails to run at all and suggests running BR Advisor. within arcsoft total media it loads the main languages screen but once you hit the UK option it fails to go any further.
running cyberlinks BR advisor and performing a test, under advanced playback results there are red traffic lights against VC1 and H264. if you click the link through to the cyberlink suggestions page it states the recommended graphics card of which the 3650 is listed.
any bright ideas? have i missed something blindingly obvious?
2Gb DDR PC3200
ASUS ATi 3650HD AGP
