HTPC Bluray upgrade
Man of Honour
15 Nov 2006
Hull
Yo fellers,
Just thought I'd get some advice on what was required to add Bluray capability to my existing HTPC setup. It's an older skt 939 system but it's running a 4400+ X2 chip with 2GB RAM and an ATI 3450 video card, all watched through Vista media centre. It's connected up to a 46" Samsung LCD.
It hasn't been without its problems. I was unable to get smooth video playback using a DVI to HDMI cable, but playback is fine with the VGA connection - the tradeoff being a comparitively washed out picture in comparison to digital (poor black levels in particular). Not really looking for a solution to those problem (unless someone has an epiphany!), but I want to get the best possible results with this upgrade.
So, with this in mind, any recommendations for a BluRay drive and upgraded video card? The system plays H264 encoded HD at the moment, but am I right in thinking Bluray relies much more on the video card for decoding and playback? Any new vid card would have to be passively cooled for noise, and hopefully would have native HDMI output (am I hoping for too much if I wonder whether this might 'fix' my digital playback problems with going directly from HDMI - HDMI?!)
Any comments appreciated.
Have you tried a different DVI-HDMI cable first?
in terms of upgrades what about these?
Sony BDU-X10S Blu-Ray Reader Serial-ATA Drive - Retail
£54.99 inc VAT
£47.82 ex VAT
Sapphire ATI Radeon HD 4670 Ultimate "Passive" 512MB GDDR3 TV-Out/DVI/HDMI (PCI-Express) - Retail
£72.44 inc VAT
£62.99 ex VAT
Regarding the different cable, yes, I've tried two separate cables both with the same results. I was considering buying an expensive cable but heard conflicting reports on whether they actually make a difference or not, so couldn't decide whether it was worth investing in one.
The parts you suggest look fine to me. I think if I went for them I'd buy a half decent HDMI cable and see what happens. Can't exactly make it worse!
I was also wondering about sound. At the moment, I have the rear audio output connected to the TV for normal telly watching, but I also have a cable running from the front audio jack on the case to a Bose sound system for movies and the like. I'd like to keep the ability to use both sound sources, but is there and option to run the rear audio through the video card to dispense with the extra audio cable back there? If I did this, would I be able to keep the front audio as well?
Nothing I'm running an identical system and it plays fine. Apart from I'm using windows 7.
I'm using this card
Sapphire ATI Radeon HD 3450 Silence 512MB DDR2 TV-Out/DVI/HDMI (PCI-Express) - Retail
run on a £2 dvi-hdmi cable
