HTPC Build Check
6 Dec 2006
Barnsley
Hi all,
Looking to replace my current HTPC and make it a little smarter in the living room.
Below are the components I want to buy and make sure are all compatible?
New:
Silverstone Raven RVZ03B Mini-ITX HTPC Case - Black (SST-RVZ03B) @ £79.99
Super Flower Leadex III 550W 80 PLUS Gold Modular Power Supply - Black @ £67.99
Asrock H370M-ITX/AC Intel H370 (Socket 1151) DDR4 Mini-ITX Motherboard @ £104.99
Recycled:
I5-6500 CPU
256 SSD
2x 4gb DDR4
I am not sure about the Motherboard as I am getting confused with all the chip sets and all seem to support LGA 1151 so can I drop my CPU straight in? I will not be overclocking so would a different board be more suitable (cheaper) but with latest tech, m.2 etc.
Thanks guys thats great help and cheaper :)
Question on chip sets and skts, does this mean I can at a later date if wanted put a newer CPU in say gen 7/8 or 9?
6th and 7th gen Intel CPUs are compatible with 100 series and 200 series socket LGA1151 motherboards, but you'll likely need a BIOS update before you can use a 7th gen CPU on a 100 series motherboard.
8th and 9th gen Intel CPUs are compatible with 300 series socket LGA1151 motherboards, but may need a BIOS update before you can use a 9th gen CPU on some 300 series motherboards.
8th and 9th gen Intel CPUs are not compatible with 100 or 200 series motherboards. 6th and 7th gen Intel CPUs are also not compatible with 300 series motherboards.
