Been nailing down my components for a while, and I think I've finally got enough information to run it by you knowledgeable lot
* I want it to go under the TV as a media box with internal storage capacity, so I need it to be able to support two 3.5" hard drives.
* I would also like to be able to include a TV tuner at some point so that it can be used as a PVR box.
At the moment I am planning on using XBMC, probably using the live CD, which is based on stripped down version of ubuntu, but I am also open to the windows route. Since it is going under the TV it needs to be quiet, and it will be on most of the time so I would like it to use as little power as possible. I am also planning to run SickBeard and sabnzb on the box.
Case: OrigenAE HTPC S10V
Mobo: ZOTAC IONITX-F-E Atom N330
RAM: 4GB DDR2-800 (will look for some low-ish power stuff)
Media: Sony BDROM slimline laptop version (since it needs to be slot loading)
Storage: 2x WD 2TB Greens
picoPSU 150w
I had the idea of using this setup from initially looking at the M10 case, but it doesn't have enough space for onboard storage, and I really don't want to use a NAS type box if I can help it. The M10 uses the pico 150w psu so I wanted to use that in the larger S10V case to save on noise.
I have a few questions about this proposed solution:
* Will the Zotac ITX board fit in the microATX case? I have read the mountings are the same.
* Will I be able to run the above on the picoPSU 150w, so that I won't need an actively cooled psu in the box?
* Will I have enough power to add a TV Tuner card at a later stage?
I have also read that the atoms struggle with proper hi-def stuff, so if this becomes a problem, I will be adding one of the broadcom crystalhd cards to the onboard mini-pci slot in place of the wireless card. Can you see any issues which may arise from that?
If anyone can advise me with any aspect of this build I would greatly appreciate it.
Cheers.
picoPSU 150w
Cheers.
