Hi,
So I'm setting up my home cinema at the moment along with all new media/networking equipment. I have decided to build a new HTPC, that will be linked to projector, TV, based on Mini ITX to keep the size down, to run XBMC linked to a NAS.
I had considered a NUC as many here suggest but for the price it seems that I may as well just build my own as space is not a key consideration and want to make sure it is still a moderately good spec so that later in the year I can put in a GPU such as the "Radeon R9 270" and use is as a semi good gaming PC as well in the lounge on the projector
I have the following components short listed, but am unsure on:
a) what PSU I would require to make sure I could run this GPU or similar in the future that fits in this case.
b) That the case i have selected is big enough for this GPU, and aftermarket CPU cooler (is this required, I am not planning to OC). Would I be better going for a slightly larger case for airflow etc such as:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-112-SV&groupid=2362&catid=1092
c) Real world difference between chosen CPU and say the 4670K? Manly I am opting for the i5 Haswell for the HD4600 graphics
d) Is 8 gig ram enough, my existing PC has 8 gig and I built this 4 years ago (not ddr3 thou).
YOUR BASKET
1 x Intel Core i5-4430 3.00GHz (Haswell) Socket LGA1150 Processor - Retail £131.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Silverstone SST-ML06B USB 3.0 Milo Slim HTPC, Mini-ITX - Black £41.99
1 x Akasa AK-CBSA05-30BK Super slim SATA rev 3.0 data cable with securing latches - 30cm, Black £3.29
Total : £369.84 (includes shipping : £8.00).
Bear in mind I'm not looking for top spec, just something that will do the job for a while to come!!
I'm currently using my last custom build that i did 4 years ago and it just about manages to play recent games still!!......albeit not very good settings
Any feedback greatly appreciated.
YOUR BASKET
