12 Jan 2014 at 18:00 #1 MofoKilla MofoKilla Soldato Joined 28 Nov 2005 Posts 2,955 hi there i want to build a htpc and have come up with the following spec does this seem ok or could it be bettered max budget is £350 , i am gonna source a case from else where as oc is to expensive. thanks.
12 Jan 2014 at 18:56 #2 Grimley Grimley Soldato Joined 18 Nov 2007 Posts 8,213 Location Deepest Darkest Essex!! 1st , I think you need this thread moved to general hardware. This spec would be better suited to an HTPC YOUR BASKET 1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £83.99 1 x ASRock H87M Intel H87 (Socket 1150) DDR3 Micro ATX Motherboard £71.99 1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £52.99 1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) £32.99 1 x SuperFlower Amazon 300W "80 Plus Bronze" Power Supply £29.99 Total : £281.54 (includes shipping : £8.00). See here. http://www.anandtech.com/show/7007/intels-haswell-an-htpc-perspective Bit cheaper (& probably better) PSU HD better warranty. Is there a reason you need a graphics card unless you want to play games?
13 Jan 2014 at 18:46 #3 MofoKilla MofoKilla Soldato OP Joined 28 Nov 2005 Posts 2,955 yeah i would like to play games , steam big screen mode if poss. is the card listed any good for general gaming ? thanks for reply.
