Been mulling over an HTPC build for some time now, just need to get a few components and I'm off.
But had a thought..
Would this be feasable?
I have a very fast PC at home used for work, which would do all the HTPC duties I would need in the lounge.
Why not just use that?
Problem is that its in a different room.
SOME INFO:
My Network setup:
Virgin media Superhub in work-room connected via 15ft cat5 to 4 port router in the lounge, wireless turned on so I can use my Ipod Touch via wifi.
Q1:
Could I run a (say) 15ft video cable to connect my PC to my plasma via HDMI (I have a DVI-HDMI adapter), or even just normal hdmi?
*I have trunking along the wall hiding the cat 5 already installed - no problem to run an HDMI cable in there too)
Q2:
Wireless Keybaord and mouse to control PC
Obviously USB is limited to 5m (I think) so best solution is to have usb receivers in the lounge so I had a thought...
-USB Extender Over Cat 5e-
Its only a mouse and keyboard so would I be right in saying USB 1.1 would be fine for this?
Also...do these cat5 usb extenders ACTUALLY WORK?
As I said, this is just me thinking out loud...and it would be easier (I guess) just to build a seperate rig for my HTPC, but why not use what I have?
Just looking for some opinions of this, if it will work first of all and do you think its worth the hassle.
Thanks.
But had a thought..
SOME INFO:
My Network setup:
Q1:
Q2:
Thanks.
I have my PC set up in the dining room and I have a 10m HDMI cable running through to the lounge.
