HTPC Case + CPU Cooler
17 Jul 2013
I am sorry if this has come up before I searched HTPC large cooler and nothing that answered this came up.
Is there A HTPC Case that is big enough to fit a BeQuiet Dark Rock 2 as featured in the Rock Creek Gold Rush bundle?
If not is there a suitable cooler that will get that sort of overclock?
I want to buy this tomorrow and I dont really fancy butchering the inside of a Lian Li or Silverstone case to fit this bundle.
You can fit a D14 inside a bit fenix prodigy..
I have just moved my system into a prodigy and still managed to use the D14. It was a bit fiddly getting it in but with the Asus PZ877-I board it fits pretty much perfect. I swapped the 140mm fan to the back and used the 120mm in the middle and it works perfect with great temps.
Link to Cooler:http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC
Link to case:http://www.overclockers.co.uk/showproduct.php?prodid=CA-073-BX&groupid=2362&catid=2279
Thats about as good as your getting for big air coolers.
You can always use a CLC, like the H60/H80. These will fit in many small cases such as the prodigy or the Node 304.
