HTPC case help
23 Dec 2010
Birmingham
I'm trying to hind a HTPC case of similar size to Silverstone Sugo SG01F
which is: 263 mm (W) x 212 mm (H) x 393 mm (D).
-The maximum height i can have is 230mm and that would be literally touching the desk above it :/
-Depth needs to be around 340mm.
- Can be anywhere up to 600 mm wide.
If push comes to shove i could probably just git the silverstone and rotate it by 90 degrees and I'd just have to live with the cable mess xD
Cheers in advance :)
