HTPC Case
Permabanned
29 Mar 2006
Manchester, UK
I currently have an Antec 900 and i want to transfer my PC into a HTPC case to put under my TV.
I have a Q6600 and an 8800 GTS 640mb so i think i need one like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-022-ZA&groupid=701&catid=7&subcat=736
Will my 8800 GTS even fit in one of these or would i be better getting something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-NX
I would like to spend £100ish so the one above is cheaper than the HTPC case.
Any Suggestions?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-060-AN
Really good case (I have one :)).
Why not put the HTPC BEHIND the screen? (LCD/Plasma) that way can have a tower, and not hassle of "HTPC" cases which are generally small.
You don't need to even see the computer, if you use a USB IR receiver on a dongle. Apart from slotting in discs, of course.
