htpc case
24 May 2006
North Wales
Hi all...
I'm after a recommentadtion for a new case for a HTPC build. I will be recycling a 8800GTS and e3750 cpu on an ATX motherboard with a 520W corsair PSU and I would like to keep my 120mm Noctua air CPU cooler (help to keep the noise down...)
What I would like is a case that allows the DVD drive to sit flat when the case is lying on it's 'side' similar to the way this Lian Li case does.
Coulours, ideally black and I'm after a smart minimalistic look, rather than busy like many cases do. Budget, as little as possible, but up to £100 if needed (hopefully closer ot the £50 to £70 range)
Thanks for the help
Fluffy
