Man of Honour
- 15 Nov 2006
- Hull
Will try and keep this short and simple, hope the solution is too!
I have an HTPC system, running an Athlon 4400+ with 2GB of RAM and an ATI 3450 Video card, with Vista Ultimate. After messing with codecs for ages and ages, I've tried to keep things simple on this install. Media Center uses the Microsoft MPEG-2 codec for DVDs and TV, and that's fine. I've installed the XVid codec for the .avi Xvids I've made myself for archiving recordings - also fine. It's just HD giving me the problem, and I'm hoping it's a software rather than hardware issue.
Basically, to play back the .mkv files I have, I've tried both FFDshow and CoreAVC, both of which seem to have the same 'jerkiness' on horizontal pans every half second or so. Hopefully someone will know what I mean here, the picture pauses for a split second. Not noticeable in fast-moving scenes, but on slow camera movements, it annoys me.
I'm not sure what more I can do to solve this. Is there another codec I can try? Is it that the video card isn't up to the job? What's confusing me more, is that I also have some HD contained in a .avi format, and these play back perfectly, which leads me to believe that my video card is okay, but I honestly don't know what's 'behind' the .mkv and .avi containers in this case.
Cheers for any help
Cheers for any help
