HTPC confusion - which of Atom+Ion | S775 | AM2+ | i3 | Zacate to go for?! :/
15 Mar 2011
Firstly, greetings to all. This forum has been very handy in my investigations so far.
I'm on a quest to get rid of Sky and replace my Apple TV with something more capable, and am in the process of building an HTPC.
I seem to be throwing myself into a tailspin over which platform to go for though, and was hoping some of you could help me decide.
My requirements are thus:
  • Quiet running, as near to silent as possible.
  • Low power consumption, or can be woken from sleep with ACPI for scheduled recordings
  • Linux compatible (although I'm probably going to dual-boot it with Win7 for proper Blu-ray support when I add that)
  • Runs MythTV front and back ends, also runs Boxee and XBMC.
  • 720 capable graphics. (No 1080 TV yet!)
  • VGA output for the projector, on the odd occasion.
  • S/P-DIF audio output
  • Also capable of running a few background server daemons such as SABNZBD, Apache, Sick Beard, Couch Potato
  • Operating as a NAS
  • Adding a Blu-ray drive (with full HDCP playback support) at some point, although not necessary in the near future.
  • Preferably mATX rather than mITX, so I can add in a couple of expansion cards, including a DVB-S2 PCIe card I have no, adding a DVB-T card, and maybe even upgrading graphics in the future to support full 1080 (assuming I go for something like an i3 now which I believe would be pushing its capabilities a little...)
I don't see a need for wifi, as the airwaves are far too congested around here so I'm going to hard-wire it.
My first choice was an Atom/Ion combination.
I'm struggling to find the best board here though... The Zotac G-E board seems to be a good buy but doesn't have S/P-DIF output. I do have an external USB audio S/P-DIF interface that would suffice there. I spotted the ASUS 510 board which has the upgraded D525 Atom and ION2 graphics, but it has no VGA output so that wouldn't support the projector.
With these options, I'd have to mess around with getting a USB DVB-T stick to work with Linux, although the Zotac board has a mini-PCIe slot that I could use for that. Obviously I'd be stuck with the on board graphics with these, but the ION and ION2 support 1080, so that could work. Is there a huge benefit for going for a SU2300 over the Atom? The price difference seems to be about £50 over the Atom variant... which is quite a bit if the performance increment is minimal.
Then I saw the Zacate boards coming out, and they sound better - except for (lack of) Linux support. Anecdotally, it would seem AMD are way behind the curve in releasing drivers, and you can't offload video processing to the GPU. Is that correct?
Then I wondered about a low power socket 775 chip, such as an E5400, which would outperform the Atom, and couple it with a passively cooled NVidia graphics card on a mATX board. Obviously the power consumption here is going to shoot up from the Atom/ION boards, but by how much? Is it possible to underclock these so as to bring the power down?
The next option - although going up a bit in price, is the i3 option. On board graphics are not meant to be as good as the ION option, but I could again, in future (when I need 1080) then add an external card to provide better support for that.
Then I ALSO spotted the fact that Sempron chips are lower in power consumption than their Intel equivalents, and you can get motherboards with on-board Nvidia graphics, such as the GeForce 7025 chipsets, which again, might suffice at the moment. There are some really good prices available on combinations here, bringing in a mobo+cpu+ext graphics+memory in for the same price as an atom/ion mobo.
I also quite like the ASUS barebones systems - I built a pundit years ago, and was really impressed with the build quality of their kit, as well as the aesthetic look of their case. Something like the Asus V6-P7H55E would take an i3, and has the expansion capabilities I need.
But all of these options are throwing me into complete confusion over which option to go with.
I spontaneously (drunkenly ahem :)) bought a DVB-S2 pci-e card, so I know that I have a hard requirement for a slot to support that.
After that, I'm flexible in my choices.
Any help would be most gratefully received. This decision process is driving me mad. (My adhd seems to be rising to the challenge of befuddling any choice I get close to making here!)
Many thanks
David :)
I know it's only mITX rather than mATX but the Zotac Ion A board has spdif out (coax and toslink) as well as a built in DC input and VGA, DVI and HDMI outputs :) It's probably the board I'm going to go with when I get round to a HTCP assuming there isn't anything else better at the time.
To be honest it's one of the most feature packed ITX boards I've seen!
Does anyone know how this board copes with 1080p, if at all?
it's got a dual core Atom and Ion chipset so should handle 1080p without issue. The reviews I've read suggest it's fine with 1080 playback while using GPU acceleration, though I think there are still a few bugs with Flash based content that's not using GPU acceleration
A FYI - for MythTV frontend you're far and away best off at present with a VDPAU capable system (for HD output).
For 1080P the Zotac Ion should be fine (though it won't do the highest quality settings - not powerful enough). If you're going non-Nvidia chipset then an add-on GT220 or GT430 depending on which you can get cheaper (either is fine with the highest quality setting).
The only thing I'm not sure about is that you're outputting 720P rather than 1080P - this means that the output will need to be deinterlaced + scaled - I'm not sure if this means you'll need a higher end card.
I'd suggest you ask on the MythTV Users mailing list - lots of people knowledgeable people there...
See this link for VDPAU capable chips.
@zel... you are a star - cheers for the link to the MythTV email list. I'd not found that before, although I'd found a number of forums and websites. That looks ideal - I've subscribed, will read over some of the archives, and may post my initial question up there.
I'd already found the vpdau info, and this is why I was leaning towards an nvidia solution, in particular the ion/atom combo. It's just a shame that the seeming only board out there with ion2 on-board at the moment is the Asus, which has no vga output.
@blueacid: I do indeed want the DVB support - I'm planning on ditching Sky and moving to freesat. And I'd like to add a second card for DVB-T too, as not all channels are on both freesat/freeview. Whilst sick beard will get me all the TV shows I *want* to watch, there is a certain lazy satisfaction of turning on the tv and watching whatever **** it is they're broadcasting at the time, just as background noise. e.g. you can't beat cooking your sunday roast, while Dave Green is giving someone else a roasting in the background on "come dine with me". :D
As an FYI - ION has several problems
1) it doesnt work well with switches or av receivers
2) it doesnt do 24p very well.
i am looking at zacate to replace my revo 330.
Is there not a problem with Zacate though? I thought the equivalent of vpdau drivers didn't exist, so you can't offload video processing to the GPU?
Your comments are exactly what's causing me to hesitate though. I thought I was happy with my choice for atom/ion but comments like this make me hesitate!
I'm swinging again towards an AMD platform, with NVidia graphics...
I'm in rather the same situation as you.. or, at least I shall be in a couple of months!
I'm noticing that there really isn't much move on any kind of linux graphics acceleration driver for AMD/ATI (so, VDPAU for ATI then), which is a bit of a pain.. equally a Zacate system would be frugal with power.
Tough call really! :(
Actually, just found this comparison between a Zacate system and a few Atom/ION boards:
http://www.silentpcreview.com/article1167-page1.html
Seems to suggest that Zacate is (for all intents and purposes) equal. Sure the graphs are a little different but for the sake of a couple of watts of power, or the odd percentile of CPU load you might as well pick whichever board suits in terms of size and PCI-E connectors.
So given that, I'd look at the IONs... does that Asus you mentioned have DVI? I wonder whether a DVI to VGA converter would work with it.
The Asus board does have DVI, but it doesn't carry VGA - it's not DVI-I, or whatever the term is. Which is a PITA, as otherwise, it's perfect! :(
I'm wondering holding off for a little bit and seeing what develops.
Although, I'm also itching to get on with this and start building a system!
