Need some input.
I have a HTPC built inside of this case, according to the manufacturers website, it can accommodate a CPU Heatsink no larger than 135mm as per here.
Now I'd really like to fit an aftermarket cooler as my i7 tends to run hot and that's without an OC, plus I want to reduce overall noise, having the stock heatsink spin up is quite noticeable.
This Noctua is 130mm as per here. Will it fit inside my case? The numbers suggest yes but I'm uncertain.
