Hi guys,
Looking at buying a desktop or HTPC style case to move my 2nd system into.
Now the only problem i have is that i have a perfectly functioning ATX psu i would like to keep for the system.
Other factors to also consider are that it needs to be able to also house an x1800gto fitted with a zalman, 2 sata HDD's, 1 sata DVDRW (no ide devices).
I'm not picky about the size or the price, this is purely a consideration... if nothing can match the requirements i'll keep it in the atx case and work on silencing it some more, damn thing is too noisy. Would be nice to sit the system under my AMP (or on top) though....
would look nicer then just having it sat under the desk.
EDIT::
lol timing....
Yes indeed does look ideal.... and the design looks gorgeous....
The system will be getting upgraded soon with a Micro-ATX s775 board and a cheapo Core2, if a suitable case is found...
So are there any cases out there that meet the requirements?
would look nicer then just having it sat under the desk.EDIT::
silverstone lc17afaik its still the only decent desktop htpc that'll fit an 8800gtx/quad core system in addition to two optical drivers and 3 hard drives, and has the capacity for 2x 80mm rear fans, 1x80mm side fan (cpu area) and 2x 92mm front fans. oh and a full atx board. it might be a little on the big side depending on your expectations though.
lol timing....
