htpc dilemma
  • Thread starter Thread starter emu
  • Start date Start date
emu
emu
30 Jun 2005
hi guys
i have a htpc hooked up to my samsung lem40 lcd
its all housed in a antec p180 which lives behind my settee, to cut the noise down it only runs with a cpu fan and no other fans
http://www.jessg89.ukfsn.org/computer.jpg
i know something spooky is going on with hardrive 0 but i think that is a wrong temp reading
are the other temps well with in my hardware limits?
i did have the idea of backing everything up off the harddrives and maybe scaling it down to a matx set up
any ideas?
oh forgot to add i have a gigabyte ds4 and a e6300 cpu
is it worth going for one of the new 45 nm cpus to cut down temps?
Your CPU temperature is a little high considering that's at idle.
I have the P180 and rather than disconnect the fans I bought a cheap fan controller and changed the fans from the Antec 3 speed to some with 3-pin connectors that work with the controller.
The fan controller gives them a +12v nudge at startup and then drops the votage right down so they spin around 600rpm which is near as silence.
I found that having hard disks in the bottom bay with no fan resulted in higher hard drive temps, with a slow spinning fan temps are 15C lower using HDTACH !
You could get a better CPU cooler, one with heatpipes and a slow 120mm fan would be good.
Also consider blanking off the top fan outlet with a slow fan to the rear. Most of my noise comes from the top fan so I usually keep the argos catalogue on top of the ramp thing which deadens the noise but allows the air out
AD
With zero airflow in your case, your components will bake. I have a P182 for the HTPC too, got the bottom and single exhaust on low.
