HTPC/Encoding rig
21 Apr 2004
Sunny Wales
Building a new PC shortly. Apart from the everyday webbrowsing and office work this machine will mainly be used as a HTPC or encoding videos. Budget is below £350 all in. I already have 8Gb of Ripjaws DDR3 and will also be bringing an OCZ 650w modular psu into this new build. Gaming is not a priority and as such may be able to use my current ATi 4670 card. Case does not need to be a HTPC model.
Please spec away.
Intel would be your best bet. The i3 and above have quick sync which uses the IGP to boost video encoding (it works very well).
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £89.99
1 x Gigabyte H61MA-D3V Intel H61 (Socket 1155) DDR3 Motherboard £47.99
1 x BitFenix Outlaw Gaming Case - Black £39.95
1 x Sandisk Ultra SSD 60GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-060G-G25) £39.95
1 x Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £15.98
Total : £323.84 (includes shipping : FREE).
Not sure exactly what you need but that's under £350
The mobo supports USB3 and sataIII. The SSD is only sataII but it was cheap there was money left over if you wanted a sataIII SSD, I'm assuming you wanted a good sized HDD to encode to aswell?
