HTPC Fans
10 Nov 2011
Telford
I received my cooler master advanced 120 elite today and I want to try and get this PC as quiet as possible.
Currently waiting on
BeQuiet Pure Power L7 430W
Asus P8H77-I Intel H77
6670 GPU
Going to replace
80mm fan with - Noiseblocker BlackSilent Fan X2
I want to replace the 120mm case fan on the front with either of these but which is quieter and better?
Arctic F12 Case Fan
http://www.overclockers.co.uk/showproduct.php?prodid=FG-026-AR&groupid=701&catid=2331&subcat=4
or
Zalman ZM-F3
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-ZA
When running low-med, I believe so yes. Check out the specs, should give you db levels as well as cfm.
Ok.
just looked at heights for the CPU cooler its 2.5in and the one I currently have is 3in.
Any recommendations on cheap cpu coolers that are under 2.5in?
