HTPC & Gaming - First build advice
3 Mar 2011
Hi, this is my first build, what i want is a Blueray player/HTPC (XBMC) that is capable of playing modern games to a decent standard.
It will be connected to my Onkyo TX-SR 608 amp
Its main uses will be -
Watching movies (From the Synology DS1812 ive ordered)
Playing emulated games through Hyperspin (seeing as ive had to sell my games room) (Dolphin and PCSX2 require clock speeds of 4.40)
Playing some modern games, mostly racing and FPS... wife will no doubt want Skyrim
and casual internet browsing.
Any suggestions/help is appreciated.
Your basket
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
http://www.overclockers.co.uk/showproduct.php?prodid=CP-404-IN
I intend to overclock to 4.40
Lian Li PC-C50B HTPC Case - Black [PC-C50B] £149.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-236-LL&groupid=2362&catid=2282&subcat=
Space in my cabinet is limited, this fits nicely
Asus Z77 Maximus V Gene Intel Z77 (Socket 1155) DDR3 Motherboard £154.99
http://www.overclockers.co.uk/showproduct.php?prodid=MB-516-AS
mATX with great OC reviews and soundcard
Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CMZ16GX3M2A1600C10) £109.99
http://www.overclockers.co.uk/showproduct.php?prodid=MY-313-CS
Do i need 16GB? Probably not, just being greedy
NZXT Hale Power 90+ 650W '80 Plus Gold' Modular Power Supply £94.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-103-NX
Im assuming 650W will be sufficient + gold rating
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £85.99
http://www.overclockers.co.uk/showproduct.php?prodid=HD-009-CR
Will have Windows and afew other bits on
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS
LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (Retail) £79.98
http://www.overclockers.co.uk/showproduct.php?prodid=CD-107-LG
Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA2011/1366/1155/1156/775/AM2/AM3) (CWCH60) £59.99
http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS
Height restrictions limit decent air coolers, reviews suggest this is sufficient for an OC CPU, plus decrease in noise
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM £13.99
http://www.overclockers.co.uk/showproduct.php?prodid=FG-057-AK
To replace stock fan on Hydro H60
Asus GeForce GTX 670 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card £359.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-278-AS
Shouldnt need an upgrade for some time
i built a highish end pc not long ago, not to this level tho.
my main issue was fitting everything in. How big is that case? looks similar to mine, exactly the size of a standard amp. if so, be careful with gpu sizes, might not be an issue
Hi, case dimensions: (W) 445mm x (H) 167mm x (D) 325mm, so similar to an amp.
The case is long enough to fit the 11" card, there should also be over an inch top clearance for cables.
its doable then, my case looked terrible inside, one thing i would get if possible is a rear exhaust card, in such a small case i felt i didnt want the gpu pumping out heat into the case. i wonder if others agree
