Looking at replacing a 7800gtx on my media pc with a hdcp compliant one. Pc spec is an AMD X2 4800 at stock with 2 gigs ram on a DFI Lanparty UT-SLI DR mobo. Wanting to be able to run games and stuff on it too, such as Richard Burns Rally, GTR2, EvE, LFS with lots of eye candy. Looking at the two cards below unless someone can recommend me something else. Need to be quiet(ish) too.
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express)
Which one should I go for? 640mb or 320mb?
Cheers !
Cheers !
the GTX is the faster card and more future proof so to speak so if you can afford and dont mind forking out the extra £100 or so then go for it. The 8800 GTX might be a bit overkill for that res with todays games but i feel that it wont be wasted with Games like Crysis so it might be worth paying the extra for it.
