HTPC HDMI Colour Format and Range Output Help...
17 Jul 2015
Hi, I've just finished my HTPC build and just need some advice on what of the below settings I should be using thanks. The setup is like this...
HTPC
Output colour format = RGB or YCbCr422 or YCbCr444
Output dynamic range = Full or Limited
Denon AVR2308
HDMI Video Setup
Colour Space = RGB or YCbCr
RGB Range = Enhanced or Normal
Samsung UE55H6400
HDMI Black Level = Low or Normal
I used Kodi for my movie playback and this also has a setting for Limited range or normal. I will also play games now and then (GTX970)
This is all connected via HDMI cables.
Any advice would be great as theres so many settings :)
