Well, since upgrading my old rig to a snazzy new C2D system I have been pondering using my old CPU and Memory to build a basic HTPC/Media PC as low cost as possible. But knowing not much about them I have a few questions.
The CPU and Memory in question are a P4 630 (3Ghz) and 2gb of OCZ PC3200, now, are both these components good enough for a PC of this type?
What other essential components are needed for this type of PC?
It would have to have a Freeview card in it as I will be doing away with my freeview box, so could someone recommend one?
Case wise I was thinking along the lines of the Antec Fusion as it seems well priced for its spec and aesthetics, with this case I would need a mATX motherboard so are there any recommendations on this.
I think that is all if you could fill in the blanks it would be most helpful.
Thanks in advance
GazD
Thanks in advance
GazD
