HTPC minimum hardware for upto 4K
24 Aug 2006
Will this spec be suitable for a HTPC?
Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
(£49.16) £58.99
(£49.16)
TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLAD38G1600HC9DC01) £55.99
(£46.66) £55.99
(£46.66)
Intel Pentium G3420 3.20GHz (Haswell) Socket LGA1150 Processor - Retail £46.99
(£39.16) £46.99
I have Qnix monitor so I need to be able to output at 2560 minimum to DVI. Can you do HDMI to DVI at this resolution?
Also, the spec of motherboard states that it can handle 4K, encase I get a 4K tv in the future.
Grpahics
- VGA (1920x1200 @ 60Hz)
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
Not sure if I really need 8GB either...?
No I reckon 4gb is enough to be honest. However regarding the resolution questions you'd have to wait until someone that knows their stuff replies to this ;)
How about this AMD setup
Product Name Qty Price Line Total
(£46.66) £55.99
(£46.66)
AMD Athlon 5350 2.05GHz Quad Core Processor - Retail (Socket AM1) £41.99
(£34.99) £41.99
(£34.99)
MSI AM1I AMD AM1 (Socket FS1b) Mini ITX Motherboard £24.95
(£20.79) £24.95
(£20.79)
