HTPC Motherboard
Permabanned
8 Feb 2004
Hi
Am thinking about a cheap HTPC and was wondering how the Abit A-N78HD (GeForce 8200 chipset) compares to the Gigabyte GA-MA78GM-S2H. The Geforce 8200 looks like a winner but I can't find a review of it anywhere!
nope, the 780G is going to be the winner for a HTPC setup, as it has onboard decoding of HD media. you can get away with less than a 2Ghz chip which means your total price (for motherboard and CPU) is going to be about £80 tops.
and that would actually be overkill
What board are you looking at that lacks S/PDIF? I doubt that any lack it.
8200 has the advantage of 7.1 LPCM via HDMI whereas with 780G the HDMI audio is only S/PDIF. 780G has better video quality though and the 8200 audio is downsampled because there's no protected audio path. I can definitely recommend the 780G (Gigabyte MA78GM is nice), combined with a 45 X2 4050e you get a nice little HTPC. There's currently no solution for proper HDMI audio anyway.
There are some nice MiniITX versions of both chipsets btw.
if its not got any spdif then there may be spdif headers on the board it self you can conenct one upto, alternativly you could always buy a cheap ass sound card that has spdif on it? with it being a digital connection I doubt that the cheapness and quality of the actual soundcard will affect the signal.
