HTPC needs a faster CPU. AMD is confusing.
Don
18 Oct 2002
Wargrave, UK
I've got an HTPC that I built a year or so ago but I'm finding that both cores of it's CPU are maxed when decoding 1080p video. I'm also getting the odd frame drop because of it.
These are it's specs:
Athlon 64 X2 4400+
Gigabyte GA-VA69VM-S2 - http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=2500
2GB Corsair XMS2
Blueray/HD-DVD combo
nVidia 8500 with passive cooler
Couple of DVB-S cards
Twin tuner DVB-T card
All running Windows 7 RC.
So, I figure I need to upgrade the CPU. No OCing ability with the mobo unfortunately.
What can I use? The Gigabyte support site seems to think I can use AM2+ and AM3 CPUs in it but with lower HT speeds. Is this true? How bad will the performance drop be?
Or, should I just bin the mobo and buy a nice Core2 mobo and CPU?
Try CoreAVC. That's what I use to decode h.264 (BD video format).
Your HTPC spec is very similar to my own and should be more then capable.
