Hi guys,
Im not new to PC hardware or building PC's, but I have never attempted and if I am honest know little about the hardware you would want for a HTPC.
Good news is, I have graphics card spare, gigabyte windforce 960 that can be used which has a HDMI output. It is a small (ish) card and needs 1x6 pin power connector.
It will be used for the TV downstairs which is 1080p.
What I am not sure about is the rest of the specs, I would like to go for something small (ish) & quiet. I will use a wireless mouse/keyboard to control it so needs bluetooth for those to work? (I also need a wireless keyboard and mouse) - I can also connect to the internet via ethernet cable, so doesnt necessarily need wifi.
Needs to have an optical drive so we can watch DVDs. I will need an OS also. Needs to be able to work with that 960. Needs to have some storage but nothing crazy, as I wont start saving tons of videos etc, really just enough for OS with a bit spare.
Any ideas or even just give me full spec?
Also with budget, with everything going on and my lack of knowledge of smaller parts for a HTPC I honestly dont know what you could get or even how much youd need to spend? It only really needs to be able to stream 1080 videos and similar, not play games at all really. So if the cost can be kept down to maybe not absolute bare minimum, but just up a bit from that. I dont mind spending more for a decent power supply etc.
, I have not seen it go more than 75c last few uses so maybe thermal paste needed a bit of settling. To be fair its not crashed or any obvious signs of thermal throttle.
