- 14 May 2009
Hi,
I'm in the planning process of buying a first home in the next 6-8 months or so. As part of that planning process, I'm considering what entertainment setup I would like
What I would like to achieve is to be able to use either my main PC (built myself last year), laptop or a TV to play whatever music, video (including HD) files I may have. My idea is a HTPC (with its own O/S obviously) to host all the media files, connected wirelessly in a network to my main PC via the O2 broadband router and hard-wired to the TV, which would hopefully allow me to use any of the PC, laptop or TV to access any play the media held on the HTPC. I don't have any gaming consoles and have no plans to get any.
However, given the HTPC would be sitting next to the TV, ideally it should be as inconspicuous as possible - small and quiet with minimal power consumption. However, it would need some sort of grunt in order to play HD video. Are there any suggestions in terms of HTPC spec, which would fulfil these requirements?
Thanks in advance!
Thanks in advance!
