HTPC performance issue
18 Oct 2002
Riteo
Wolfdale E8200, 2 gig DDR2, using 2 Nova T 500's, Vista Ultimate streaming over homeplug HD network to 2 (soon to be 3) xbox 360 xtenders.
We keep getting network issue, and jittery slow performance through the menu system.
One extender is on the network switch connected to the media centre, so doesnt use thehomeplug HD connection, but the other 2 will be using it.
Any idea if its the network causing it, or is the box struggling?
I was having similiar problems when i was using wireless 108MBps to stream to my HTPC.
It was solved by hardwiring the HTPC to my router with a 20m RJ45 cable ;)
Now i stream 720p .mkv blu-ray files with no stuttering at all :)
Have you tried eliminating the Homeplugs with a good old massive RJ cable? This would seem like an easy and inexpensive test of whether these are the problem, although at 200mb/s I doubt it.
