HTPC question, does anyone use MADVR with an AMD 2200g?
28 Aug 2006
Hexham
I've just built up a PC to use primarily for movie watching duties, with the potential to add a GPU in future, and I'd like to set it up with MPC-HC and MADVR, the same as I had on my old 3570k/GTX980 system.
Is the 2200g powerful enough for MADVR, and has anyone got any settings I could try if they use it?
Spec for reference :-
AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor
Gigabyte GA-AB350-GAMING 3 ATX AM4 Motherboard
Noctua NH-U12S SE-AM4 CPU Cooler
Team T-Force Dark Pro 8 GB (2 x 4 GB) DDR4-3200 Memory
Samsung 970 Evo Plus 500 GB M.2-2280 Solid State Drive
Fractal Design Define R3 ATX Mid Tower Case
Corsair 750 W 80+ Gold Certified Fully-Modular ATX Power Supply
