- 24 Mar 2004
- Blackpool, England
Hi All
I have finished my mITX build now and was pondering using it as an actual HTPC. At the moment i dont have a blu ray drive in it but they are cheaper than i thought.
Current spec is i3 530, DFI H55, 2gb Ram, Sapphire 5750 GFX and Intel X25-V HDD all in a SG06 case
If i got a Blu Ray drive for it and hooked it to my telly (37" Toshiba Flat screen) via the HDMI out would the resolution be the best quality offered by the Blu Ray or would anything limit it?
Currently i use the PS3 for Blu ray downstairs but id like to move that upstairs so i can use it more as it's the girlfriends TV and for some odd reason she doesnt want to watch me play on the PS3 for hours on end...
Thanks!
Thanks!
