HTPC re-case advice
3 Jul 2004
Hi guys,
I am in the position that I have to re-case my HTPC.
Currently microATX board in a Antec Fusion remote case.
I need a case, as small as possible, that will take the current M/B, no graphics cards as I am using onboard graphics and sound.
I am really struggling to find anything small, ideally it would be 300x300x90 mm
Any advice would be appriciated.
Coolermaster Elite 100.
Dimensions 262 x 69.6 x 318 mm (WxHxD mm)
Just built a little Hudson system into one of these for a mate,I couldnt get over how small it is for an M-atx case.
Tiny case for M-atx,cheap as chips and easy to source!
That is not bad, couldn't see that earlier when I was on their site :)
Well Skilty managed to fit his mATX board into a case which I'm pretty sure itsn't designed to take it: http://forums.overclockers.co.uk/showthread.php?p=18518722#post18518722
Might want to ask him what he used.
Excellent I'm off for a read.
The Coolermaster seems to be the way to go, can anyone recommend a low profile AM3 cooler that would suit this case?
Cheers
Excellent, thanks for all the advice, all the old gear now sitting in its new case, with new H/S.
Now off to find a S/H 775 quad core to fit in this shuttle for the kids :D
