- 18 Oct 2002
- Cambs
I have recently setup a HTPC running WinXp and WinXp64. I'd like to control it using a remote control that works for Theatertek and can do stuff like turn it off etc.
I already have a HArmony 525 remote so whatever I add to the PC i'd like to be able to control it via the harmony as well so I may simply need an IR reciever.
It would have to sit on top of my PC however as my HTPC is in a coolermaster case with a door so can't go in the a 3.5 or 5.25" bay.
I have no plans to use my HTPC for TV recording at the moment as I have sky+ which is why I haven't simply installed MCE and chosen to use the MS remote. But if I do go down that route ie having a third OS with MCE I'd like to use the IR reciever to work with my harmony or my advanced xbox 360 remote(which I believe functions as a full mce remote anyways)
Ok that's all a bit complicated and there seems to be ooddles of different remotes for PC's out there so i'm confused by choice really.
Can anybody make a good suggestion at what I should be looking at.
Thanks in advance.
Thanks in advance.
