Is this the one?Hama MCE compatible. Have 3 of them here and can be had way under £20 (more like £12). needs a little work in setting up key mappings, but cheap, cheerful and works wherever you point it in the living room.
Will this HTPC remote work on HTPC and other video players? Seen one for £13Is this the one?
Casterina said:![]()
Is this the one?
All my buttons work (I'm running on Linux here though). I'm using a small addon program which sits and reads USB keystrokes and translates them into xbmc keypresses. See this: http://trac.xbmc.org/ticket/8827 ticket. I've not really tried it with Windows (linux all the way with xbmc here).I used to use a similar one, and for basic control of XBMC and other media players it was fine. That type are all pretty similar in function. They emulate keyboard and mouse, rather than operate as a MCE remote, so a lot of buttons don't work. That's not an issue if all you need is basic cursor control and media playback controls. Play, stop, etc.
