HTPC Spec Check, Stock Cooler Qu?
5 Mar 2007
Macclesfield
I’m about to order the below for a HTPC, anyone see any problems?
I’m a little concerned about the stock cooler on the 7750+ Black Edition, anyone know if its quite enough for a HTPC? If not can anyone recommend a cooler that will fit in the case?
Thanks
Your basket
Product Name Qty Price Line Total
Antec NSK 2480 Desktop Case - Black/Silver (380W Earth Watts PSU) £86.24
(£74.99) £86.24
(£74.99)
Gigabyte GA-MA78GM-S2H AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard £79.34
(£68.99) £79.34
(£68.99)
Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS) £78.99
(£68.69) £78.99
(£68.69)
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - Retail £76.98
(£66.94) £76.98
(£66.94)
AMD Athlon 64 X2 Dual Core 7750+ Black Edition 2.70GHz (Socket AM2+) - Retail £48.99
(£42.60) £48.99
(£42.60)
OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500C5 Dual Channel (OCZ2G10664GK) £33.99
(£29.56) £33.99
(£29.56)
Sub Total : £351.77
FREE SHIPPING (DPD Next Day)
VAT is being charged at 15.00% VAT : £52.77
Total : £404.54
The CPU is more than enough for Hi-def movies and tv, I use the E2220 in mine without any problems.
The stock cooler should be fine, I had the Thermalright SI 128 when I had my Antec.
I'd say to try it, if you notice it as being loud you can always throw an after market cooler in afterwards if it's noticeable.
Even with HD content though, most CPUs won't be taxed enough to need the fan at full tilt.
You may even want to try a small overclock/undervolt. Heat is proportional to the square of the voltage, so even a fairly small drop in the voltage can produce surprisingly large drops in temperature.
Sounds like a good plan
Cheers
