Right,
I'm trying to sort out speccing out a Home Theater PC, and in honesty, I cant work out what I need... ideally I want to be able to put 2 dual tuner TV cards in the machine and therefore have the capability to record up to 3 channels and watch 1 other at the same time (Freeview) (and I don't know if this is technically possible, so please correct me )
Sound wise, I want to hook it up to an amp with a 5.1 setup (not yet bought, will post on the av section shortly!) so ideally an onboard soundcard that has optical out id imagine is what I need?
please spec it up that I need everything that goes in the case, including the case... I want it to be silent really.... ideally small, powerful enough to play back HD content when I get it, and probably 300 ish gig storage......
Budget wise, as cheap as possible really... willing to go AMD or Intel
