Your basket
Product Name Qty Price Line Total
Gigabyte GA-P31-DS3L Intel P31 (Socket 775) PCI-Express DDR2 Motherboard £39.99
(£46.99) £39.99
(£46.99)
Antec NSK 4480B Mini Tower Case (Black) - 380W Earth Watts PSU £45.99
(£54.04) £45.99
(£54.04)
Asus ATI Radeon EAH3650/HTDI/256M HD 3650 256MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail £43.99
(£51.69) £43.99
(£51.69)
Pioneer BDC-202BK 5x BD-ROM + 12x12 DVD±RW Serial ATA Dual Layer ReWriter - (Black) - OEM £72.99
(£85.76) £72.99
(£85.76)
Seagate Barracuda 7200.10 160GB SATA-II 8MB Cache - OEM (ST3160815AS) £26.99
(£31.71) £26.99
(£31.71)
Intel Celeron E1200 1.6Ghz Dual-Core Processor (LGA775) - Retail £25.99
(£30.54) £25.99
(£30.54)
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £29.99
(£35.24) £29.99
(£35.24)
Sub Total : £285.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £12.95
VAT is being charged at 17.5% VAT : £52.30
Total : £351.18
sorry about the small HDD, i know its not ideal but i couldnt fit a bigger one in without going over budget, change to a bigger hdd if you can.
picked a e1200 over a e2160 due to budget and due to the fact that the majority of the processing work for decoding media will be done by the GPU anyways.
not sure if Graphics card has HDMI output or HDMI to DVI converter included, check before you buy, or dont check if you have one lying about spare.
get cheaper ram if you want, i picked that RAM, as it matches the stuff in your sig so it will give you a chance to replace your main pc's ram if anything goes wrong there while you send it back and with it being ram you used before, i guess you trust it.
no tv cards, OS, and other parts included as that goes too far over budget. i expect you to add them on at a later date or give us a bigger budget to play with.
