HTPC spec
1 Dec 2005
Stoke on Trent
Well the s939 stuff was broken so ive decided to splash out...
Hows this look, will the onboard GFX on the G530 cope with 1080 HD stuff and bluray playback? Cant use a GFX card as theres only 1 slot which id need for the TV card :)
can you get a pcie riser that will give you two slots (okay may split lanes but at least you will get a better GPU ?)
