I'm wanting to build an HTPC/Storage computer and could do with some advice.
I have been using a laptop for the last 4 years so am out of touch with what would fit my requirements. The PC will be hooked up to my receiver via hdmi and will be required to play full HD BD rips without issue.
Budget is basically as low as possible but I don't want to find it starts stuttering etc and it may be used for a bit of desktop use but will be on 24/7 regardless. As I also need it for storage the case is the biggest issue for me, I need at LEAST 4 3.25" bays but don't want it to be massive.
Doing some rough browsing am I right in thinking an mATX AMD motherboard plus CPU (Something like an A6 just to ensure there's enough power?) and a mATX case which should provide enough bays.
Any help appreciated. Ideally as cheap as possible but don't want to go to cheap to compromise and have stuttering, was hoping £250ish would get me most of the way there. As it will be running XBMC would a small SSD be the best as it will need to come on and up quickly as possible, I have a couple of external desktop HDD's (3TB worth) that I will take out of their cases and chuck in. Would also like to use my harmony remote along with it so assume an IR receiver is required.
